No revelation here but... - BMW M5 Forum and M6 Forums
BMW 1 Series M Coupé, X5M and X6M Forum Forum for X5 M, X6 M, xDrive35i, xDrive50i and xDrive30d. Also for X5 4,8i, 3,0si, 3,0d and 3,0sd.
post #1 of 1 Old 16th January 2014, 04:11 PM Thread Starter
JM1602
I hope this helps someone else.
Recently had to replace the starter on the M5. Would usually DYI this but it's very cold at the moment in my driveway. Took the car to a indy mechanic I've used before and trust. Replaced the starter, no issues. My car periodically throws the secondary air pump code which I clear using the OBD2 reader from under the dash. After the starter change, code reader shows error1 and can't connect with the car. Bought a new reader, same problem. Scratched head all day then opened to the hood and found the mechanic hadn't screwed down the cover of the 21 pin connector under the hood. It will only read one or the other, not both. Problem solved.
JM1602 is offline
sport mode revelation twalker294 E39 M5 and E52 Z8 Discussion 34 18th June 2011 07:27 AM
Whinning Noise Revelation! mswartz E39 M5 and E52 Z8 Discussion 12 13th February 2009 05:28 AM
