Old 2nd March 2007, 19:20   #1
puppypilgrim
puppypilgrim's Avatar
Garage: Alpina B10 BiTurbo (AlpineWhite)
Send a message via Yahoo to puppypilgrim
Sherlock,
What does the B7S feel like to drive in normal mode? What does it feel like when you push it? What does it feel like compared to the B10 Bi-Turbo?
Thanks,
1990 BMW Alpina B10-BiTurbo #37
puppypilgrim is offline
Old 5th March 2007, 19:28   #2
Sherlock
Garage: B7 Turbo Coupé (247, Alpin white); B10 BiTurbo (334, Alpina Blue); Aston Martin V8 Vantage 1980
Originally Posted by puppypilgrim
Sherlock,
Thanks,
It's a challenge to provide a complete answer on these two beasts, but I will try .
Note that I have a B7, not a B7S. And it's an early model, with the Pierburg mechanical injection and E12 chassis . This makes a big difference, especially with the latest B7 turbo (serie III), which has an improved chassis, 3430 cc engine from the 635, Bosh injection, katalysor and ABS . This beast is even stronger (more torque), and in a sense closer to the B10 biturbo than my B7.
So here it is.
Idle: largely dependent ot outside temperature. There is an automatic choke (remember , this car was created back in 1979) which increases the idle rotation when cold. By 0°C, the rpm at start up will easily reach 1600, which makes the car very noisy, and difficult to drive (red light start ups are very hard to succeed without stopping the engine).
When hot (> 25°C), the idle can go down until 800 rpm, which makes the car a bit shaky, as the engine suffers to maintain such low rpm. Ideal outside temperatue is 15°C, allowing an rpm of 950.
Driving in town: painful. The suspensions are stiff, and the chassis does not feel to work very well "together". This leaves a feeling of sometimes "loosing a wheel" when driving on cobblestones, tram lines or irregular roads (not unusual in Brussels downtown). (I compare with the other extreme: my daily ML with Airmatic suspension, where I don't feel absolutely nothing - like a flying carpet).
In town, the engine never reach the levels where the turbo starts charging, so the car clearly lacks torque, and moving smoothly in the traffic is something you have to forget. Again, my ML -diesel- , with its enormous torque and instant response, is much more prompt to change lane or overtake.
Steering: the assistance is far from oversized. In parking maneuvres, it's rather exhausting, given the weight on the front train, and the car's dimension (4,75 m). I must say the visibility is excellent though, due to the very large and high windows .
Leaving town for small roads.
OK, leaving the town, and driving in the nice 2 lane roads of the Brussels south suburbs (lots of golfs, lakes, castles, nice villas,...). At the first possibility, leaving the foot in the gaz pedal, to see what the B7 really offers. So here it goes, a straight line, 400 m , kick down ...and ... .... ..... nothing happen during, at least, 3 seconds. Except a "whhizzz" coming from the engine, and the turbo needle climbing up to 1 bar overboost. There you feel something is happening BUT, too late, the straight line is over, you need to brake for the next turn.
And this is really one of the key characteristics of the old B7: the turbo lag is so long, you'd better anticipate any acceleration by 3 seconds.
So unless you have a very long & empty straight line in those small roads, it's again very frustrating. An overtake can become a dangerous maneuvre. The best way to enjoy your B7 on such roads is to open the sunroof and gently cruise at 40 mph. The noise is rather deep, not too loud, the confort is very good on good roads, and the car starts feeling more agile than in town. The car catches almost everyone's attention, I can't count the thumbs up since I have it.
On the autobahn
After the small roads, time to take the 4 lanes motorway, and let the engine express itself.
As you may imagine, the real B7's territory, the place for which it was made for. Launching the car in 1st gear will not give you a full picture, as the turbo does not engage in 1st gear . I don't know if it's only mine or all early B7, but it's like this, the power comes in second gear. There, as the 3000 rpm are passed, and with the foot down the gaz pedal, my god, it's a hurricane. And yes, the boost is stronger than on the B10. Only, it last not as long as the B10. It's useless to leave the B7 climbing after 5500 rpm, as there is no much to gain. (again, maybe mine, after 26 years...). But between 3000 and 4500, it it absolutely stunning, whatever the gear.
And there comes the secret of this B7: on the motorway, cruising at 120 km/h, the engine rpm is 3000, and the turbo is already "alert" (0,2 -0,3 bars of boost). So, no more lag. If you need to overtake, just gently touch the gaz pedal, and the car goes like a rocket. Staying in 5 gear, it only takes 5 to 6 seconds to go from 120 to 160 km/h, and it continues to push like a boeing well beyond 200 km/h (but you won't stay long at that speed, because noise, steering and suspensions effects make you feel driving at 350 km/h). In the B10, the boost is of course present, but more linear, in a more controlled way. The great asset of the B10 is that the power keeps up and up until 6500 rpm, which is not the case at all on the B7.
Braking at these speeds, without ABS, and relatively small discs, is another experience. Any modern car today has lot more assistance, and much more grip on the brakes than this B7. You you need to be extra careful, remember that brakes are sensible to the pressure you put on the pedal (something we forget these days), but if needed, the car will stop strongly. Mine is equipped with pagid pads, very efficient.
In conclusion, I would say that the B7 is truly a car to be driven in certain circumstances only, in particular on "autobahnen". There, it can provide sensations experienced in no one other car, including the B10.
The B10 is for me a much, much more modern car, which can be used daily despite its exceptional level of performance . To me the B10 is quiet close to a B5 in terms of efficiency and driving sensations (the B5 is even more "remote" from the road than the B10: less noise, less speed sensation).
That's it, from a lucky owner of both, and a B3 biturbo on order
1981 AlpinWhite B7 Turbo Coupé (#247)
1991 Sapphireblue B10 Bi-Turbo (#334)
1980 Aston Martin V8 Vantage
Sherlock is offline
Old 5th March 2007, 19:38   #3
kees
Administrator
Garage: magic moderator wand
Great write-up Sherlock! It was so comprehensive that it deserved a separate thread!
You never mentioned the B3 BiTurbo! I was wondering why you were selling the B3S. So tell us more!
kees is offline
Old 5th March 2007, 20:18   #4
puppypilgrim
Thanks for the detailed and descriptive write up. I will probably never get a chance to drive a B7 or B7s. That is why I needed to ask.
Much appreciated,
Victor
Old 6th March 2007, 00:51   #5
Rockwell_
Rockwell_'s Avatar
Garage: ALPINA B10 Bi-Turbo #430 Diamantschwarz -92
Thanks for sharing. I was almost with you
Can't wait for the summer to get BT out of garage.
Diamantschwarz 05/92 ALPINA B10 Bi-Turbo #430
Rockwell_ is offline
Old 16th August 2008, 16:17   #6
bmb7t
Garage: E28 alpina B9
I am checking this topic a bit late but this is an excellent one. And who better than Sherlock to compare a B7 to a B10 BT.
It is amazing as taste change over the year. My top choice has always been and is still a E28 B7 but I have to admit that the line of the E24 is stunning. I so regret to not have bought the one that I could have (10 years ago). At the time, I was surprised by the "analog" extra indicators on the dash. I only knew about the digital ones in the vent. But now, I have to admit that these extra round indicators give a real special character to the car: almost like being in an airplane. Reading the comment, it seems that the older B7 are very precise machines (Piersburg injection!) requiring precise care, exact temperature...As indicated, not everyday cars but more maybe for a weekend ride or special event. But as the years pass, these exceptional machines are now becoming part of the history and reflect of the times of late 70s-early 80s.
Ahh, it must be such a difficult choice everyday for Sherlock: what do I take today? The B7? The B10 BT? the B3? ...unless there is snow and then the ML should be the easy choice!
bmb7t is offline
Old 16th August 2008, 22:04   #7
alpina
Garage: Csi-T5R-Tdi
Very interesting for whom it wants to choose between the different models of b7, since me
Someone has driven other models b7 II or III?
alpina is offline
Old 16th August 2008, 23:06   #8
Sherlock
Complement to my report:
You may have felt from my report in March 2007 above that the B7 serie 1 was a rather "difficult" car to drive on every roads else than motorways, and that the engine was merely to be used up to 4500 rpm.
Since then, the symptoms that existed on my B7 became more serious. Not only one, but several symptoms:
1. Handling (rear dampers have been replaced and chassis has been reinforced as it was found out that the rear differential's fixation to the chassis was partly cracked !! )
2. Start up, ignition (new spark distributor has been fitted)
3. Engine running. There, I'm busy since December 2007, first with my local "alpina" specialist, now with Alpina Buchloe through the Belgian representative, to cure all possible causes of a bad running (as said, running over 4500 was not very good, and this went worst in late 2007, to a point that the B7 was not able to drive over 100 km/h).
I must thank our member Mike323i for his guidance along this journey (see Alpina B7 turbo E12 Pierburg service manuel. )
In a nutschell, everything that could have been the cause has been checked, overhauled or replaced:
New : fuel pumps, fuel hoses, sparks, wires.
Checked and overhauled by local mechanician : turbo and wastegate;
Rebuilt as new by Alpina Buchloe : Pierburg regulator (done) and Pierburg Injection Head (ongoing).
The belgian representative should receive the injection head from Alpina Buchloe next week or so.
It was found out that the radiator was leaking, so it has been replaced as well (hand made as the piece is not available anymore).
In total, I expect the bills to amount to 8-10,000 € to cure all above mentioned issues.
I hope the B7 I will collect after all this will finally be the right one. I will let you know.
Anyway, don't count on your luck to avoid the traps of such cars. They are difficult to maintain, it is not a legend. If you intend to own one, you should be prepared and equipped with patience and finances.
I was told, about the B7 E24: "great car but they are two issues which, if they happen, are really bad: the fuel injection misfunction (tyipcal to early B7) , and the cracked chassis around the differential (E24 illness, aggravated by the B7 torque).
Lucky me: I got them both, the same year !
Sherlock is offline
Old 16th August 2008, 23:15   #9
alpina
Garage: Csi-T5R-Tdi
Not, I want to buy a model the II or the III in a condition the possible better thing even knowing that sera costly of buying...
alpina is offline
Old 17th August 2008, 00:05   #10
kees
Administrator
Sherlock - sorry to hear your issues. Thank you for listing them for others to learn from.
Hope to hear that your B7 is in perfect condition soon!
kees is offline
B7 Turbo Coupe, serie I or II? 2mcruise ALPINABoard.com | BMW Alpina Discussion 11 19th July 2007 23:02
Boost pressure on B7 Turbo E24 Sherlock ALPINABoard.com | BMW Alpina Discussion 5 22nd October 2006 22:33
Very cheap B7 Turbo Coupe on eBay kees ALPINABoard.com | BMW Alpina Discussion 2 24th March 2005 09:10
e24 B7 Turbo Andy G ALPINABoard.com | BMW Alpina Discussion 3 24th January 2005 21:31
Subjective comparison B10 vs B7 Erik ALPINABoard.com | BMW Alpina Discussion 5 2nd December 2001 21:15
Page generated in 0.19484 seconds with 11 queries
