Old 28th November 2005, 14:01   #1
Adam
Adam's Avatar
Garage: R32
Send a message via ICQ to Adam
B8 Suspension woes...
Dear All,
My B8 handles like absolute rubbish at the moment Its hard to describe it, but i would say that the steering wheel feels like it is connected to the wheels via rubber band. I ahve no confidence at high speed, the car kind of just wallows and reacts slowly.
I replaced the tyres in the front with Michelin PS2's 235/40's. Does anyone think this could cause the car to handle so badly? I then almost immediately took the car in for a service (drove 10miles or so) to the BMW dealership where they replaced shocks and bushes. Got the car back and then realized that there was something wrong. I immediately thought that the suspension settings were all out, not so, as i took the car to another dealer...and they said all was fine.
Should i replace the front tyres? What are the Alpina recommeded sizes? I know these are impossible to get, but perhaps i could source this size in continental sport contact 2's...
thanks for any help,
adam
1995 Alpina B8 4.6 #10-(engine blew up. sold)
2001 BMW ///M5(sold)
2003 RUF R turbo
1990 RUF CTR
2006 VW Golf R32 DSG
2005 e60 M5 (sold)
2007 997 GT3 RS Carrara White
2008 Renault Clio 197
"You know it is kinda ironic, these old people are being kept alive by the organs of the young people they ran over" - Chief Clancy Wiggum
Adam is offline
Old 28th November 2005, 16:04   #2
DaveW
Garage: Alpina B10 Bi-Turbo in Macau Blue
Re: B8 Suspension woes...
Hello Adam,
First of all don't stress - unless you have some serious and previously unreported chassis damage, then all your problems can be solved!
Now, you mentioned this before in one of your mails, tyre pressures are very important and at this time of year when temperatures drop, it's entirely possible that tyre pressures need to be checked and altered.
Second - tracking. British Roads are awful and that's being polite. Just driving the Bi-Turbo along some sections of the M25 can make you feel like the front end is disconnected from the back - the wheel ruts caused by heavy lorries just grab the steered wheels and make the car move all over the place. That is however, because I have a very neutral steering setup with very little toe-in. Have your tracking checked and see if they can 'dial in' some stability.
Third - How are your bushes? If your pressures are ok, tracking is ok and BMW say nothing is falling off, how are the actual bushes at ride height? Most cars will sit differently while travelling at speed to when parked up and stationary - get the car checked at ride height - a geometry check at ride height will probably show up worn bushes as the measurements will 'move around' as the test progresses.
Other - Just a process of eliminating wear - streering uj's, steering component mounts etc.
Overall, I can't believe your B8 has a problem that is not going to be simple to fix - the hardest thing might be the diagnosis!
Cheers,
Dave.
DaveW is offline
Old 28th November 2005, 22:43   #3
Adam
Adam's Avatar
Garage: R32
Dave,
Thank you very much for your informed answer , much appreciated
all the best
adam
2003 RUF R turbo
1990 RUF CTR
2005 e60 M5 (sold)
Adam is offline
Old 28th November 2005, 23:54   #4
Stevie
Stevie's Avatar
Garage: e34 540i, Orientblau
Originally Posted by Adam
Dear All,
adam
235/40 17 is the correct Alpina size for the fronts, only the rears are difficult to obtain. As for PS2, only a Rosso is on par, and don't even try a Conti. Definetly 2nd rate....
I'd check all bushes, or just replace them if you havent allready. If you want the front wheels kept in place better use new alloy "banana's" from an e30, they have one less rubber mounting. There are also some improvement available rubberwise, especially helpful if you're hard on brakes. Consider E30 M3 rubbers for to hold them, but press them in with the excentric hole facing downwards, or you'll lose too much steering-feedback with the big heavy motor up front. You won't mind the extra camber, but avoid the extra castor. That means turning it 90degrees from the e30-M3-intended fitment arrow.
As far as I can remember there was a huge thread about B8 suspension about a year ago, I'll see if I can find it for you.
Edit: Here you go: Brakes and Suspension for B8 4.6
Dragracing a BMW is like taking Jessica Alba fishing. Some might considering it fun, but think of what they missed....
Stevie is offline
Old 29th November 2005, 02:06   #5
m5 killer
Garage: b10 bi-turbo blue/e30 m3 cab m5 engine conversion macau blue
stevie i got you wrong on the contis mate they are way better than the ps2, im using them on the bi-turbo now and they are good.
shes alpina blue with two turbos and kills m5s her name is m5 killer...then theres hartge e30 cab with a monster engine her name is bird and shes a naughty girl. then theres the other cabrio the 320 clk jasper blue with every extra available. oh yes and the 4x4 cossie she only comes out for a laugh.....and weve now got bird2 shes got 470 horses two turbos and is japanese (SUPRA)......also being added R1 yamaha and a monster 4wd japanese killer just for fun in the mountainsalso just added to the fleet is a 2002 porsche 996tt in silver full options and auto with the old tip-tronicjust arrived vw touareg v10 tdi diamond black, fully loaded tiptronic with 22" rims. just arrived gunmetal grey toyota celica gt4 2.0 turbo 4wd 360 bhp with t4 turbo, running out of space for cars, RS4 CABRIOLET IN PHANTOM BLACK JUST LANDED
m5 killer is offline
Old 29th November 2005, 13:03   #6
Adam
Adam's Avatar
Garage: R32
We run Conti sport contacts on most of our cars and they are really superb,
thanks for the input, really appreciated.
all the best
adam
2003 RUF R turbo
1990 RUF CTR
2005 e60 M5 (sold)
Adam is offline
Old 30th November 2005, 01:17   #7
m5 killer
all the best
adam
adam if your having trouble with getting tyres, i can get you the b8 sizes in london.
Old 1st December 2005, 23:50   #8
BlackB8
BlackB8's Avatar
Garage: Alpina B8, Black
Just as a note, the last time I changed to new tyres I did feel a difference at first from my old tyres - but this was mainly due to the fact that the old tyres were pretty worn and the new ones obviously had a couple of millimeters more tread. The feeling wasn't as strong as you described it but maybe in your case it is just a combination of a lot of things at the same time.
Cheers, Alex
by the way, did you also check your suspension in the rear (bushes, shocks, etc)
BlackB8 is offline
Old 2nd December 2005, 00:59   #9
Adam
Adam's Avatar
Garage: R32
Yep suspension was checked alround, its really puzzling me, i have a quite a long motorway trip tomorrow, and will report back...
cheers for the heads up m5 killer too
all the best
adam
2003 RUF R turbo
1990 RUF CTR
2005 e60 M5 (sold)
Adam is offline
Old 3rd December 2005, 16:38   #10
Tinker
Tinker's Avatar
Garage: Alpina B8 Touring
Adam, soory to hear about the car.
From what you say you've changed all the bushes and tracked the car ... then can't see what is wrong ... does the steering wheel vibrate when braking/straight ahead?
Have you curbed a wheel?
As has been said before it is just the rears you can't get anymore (well you can in the UK, but they are no longer in production), I have been recomended by Alpina to put 245's on the rear, don't know if anyone has done this.
Tinker is offline
Suspension woes...experts opinion needed. Sweetsound2001 E39 M5 and E52 Z8 Discussion 8 19th June 2005 16:50
B8 suspension woes. Adam ALPINABoard.com | BMW Alpina Discussion 5 20th May 2005 00:02
More Suspension woes (SLS) Brian M5 E34 M5 Discussion 3 11th April 2005 14:39
Question about the corvette and suspension in general? paulh GTBoard.com: General Sportscars 1 10th March 2005 18:51
Brakes and Suspension for B8 4.6 BlackB8 ALPINABoard.com | BMW Alpina Discussion 240 31st August 2004 09:38
Page generated in 0.20877 seconds with 11 queries
