Old 13th May 2005, 11:14   #1
Adam
Adam's Avatar
Garage: R32
Send a message via ICQ to Adam
B8 suspension woes.
Need some advice from you Alpina experts.
My car has 110k km.
Up until yesterday afternoon i would have said that my B8 had a beautifully balanced, stable suspension setup. A real joy to drive at high speed, confidence inspiring if you will.
Now however, literally the suspension has changed like night and day. High speed the car fidgets, almost as if one wheel wants to go another direction to the other one.
The car wallows at high speed, and is certainly not stable on the autobahn.
I have several theories.
A) I hope it is this one, my suspension rubber bushes have decayed and subsequently expired, this happened to the ctr, and the ctr had similar symptoms to the b8.
B) The car is 10 years old and thus perhaps something more expensive has happened and the shock absorbers have gone awol...
Any thoughts, im scratchig my head, and wholly peeved,
all the best
adam
1995 Alpina B8 4.6 #10-(engine blew up. sold)
2001 BMW ///M5(sold)
2003 RUF R turbo
1990 RUF CTR
2006 VW Golf R32 DSG
2005 e60 M5 (sold)
2007 997 GT3 RS Carrara White
2008 Renault Clio 197
"You know it is kinda ironic, these old people are being kept alive by the organs of the young people they ran over" - Chief Clancy Wiggum
Adam is offline
Old 13th May 2005, 17:47   #2
alpinab846
alpinab846's Avatar
Garage: Alpina B8 4,6 Montrealblau
Re: B8 suspension woes.
Just check the rear trail arm bushings (Tonnenlager Hinterachse/unterer Lenker)and the front trail arms and bushings (unterer Querlenker inkl. hinterem Lager)
The Michelins arent very good with low profile too.
I had the same problems-we sorted this out with a Schnitzer Suspension kit and my custom made sway bars-just ask Michael, he drove my car last year-and he was satisfied.
I think user mill has one front sway bar, i have one for the rear end. The sway bar is made to Schnitzer specifications.
[img]http://www.cpschwick.de/pics/Alpina8.jpg[/img]
Hubraum ist durch nichts zu ersetzen- außer durch noch mehr Hubraum...
alpinab846 is offline
Old 14th May 2005, 01:30   #3
BlackB8
BlackB8's Avatar
Garage: Alpina B8, Black
Peter is probably right with the bushings. I would check these first. Mine were completely torn when I changed them.
Cheers, Alex
BlackB8 is offline
Old 14th May 2005, 22:36   #4
kAtAnA309
Garage: BMW M3 GT British Racing Green
Tyres could also be the culprit... I put a set of cheap'n'crappy tyres on the GT for a driftcourse. First time I drove them on the highway I stepped out of the car looking a bit white around the nose, because of all the wobbling the rearend was doing.
Seems a bit unlikely to just happen overnight though, but might be worth looking into. Checking the pressure would be the first step I guess.
Good luck with it, hope to see you around the ring sometime.
Gerrit
M3 GT #104
kAtAnA309 is offline
Old 15th May 2005, 16:30   #5
Adam
Adam's Avatar
Garage: R32
Hi Gerrit,
Cheers for the advice buddy, i think it could be the tyre pressure, will check it now.
all the best
adam
Adam is offline
Old 20th May 2005, 00:02   #6
DaveW
Garage: Alpina B10 Bi-Turbo in Macau Blue
Originally Posted by Adam
Hi Gerrit,
all the best
adam
Hi Adam,
I don't suppose this is bothering much now.... just checked the date and guess you must be out playing in the new toy???
Hope it turns out to be every bit as good as hoped!
Dave.
DaveW is offline
More Suspension woes (SLS) Brian M5 E34 M5 Discussion 3 11th April 2005 14:39
Question about the corvette and suspension in general? paulh GTBoard.com: General Sportscars 1 10th March 2005 18:51
Brakes and Suspension for B8 4.6 BlackB8 ALPINABoard.com | BMW Alpina Discussion 240 31st August 2004 09:38
Press Release 4: The suspension of the M5: Ensuring a high degree of agility Gustav E60 M5 and E61 M5 Touring Discussion 0 4th July 2004 22:03
Press Release 4: The suspension of the M5: Ensuring a high degree of agility Gustav Most Memorable Threads' 0 4th July 2004 22:03
Page generated in 0.20771 seconds with 11 queries
