Need Left Rear Bi-Turbo Self Levelling Suspension Unit - Page 2 - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > BMW M5, M5 Touring, M6 and Z8 Forums > ALPINABoard.com | BMW Alpina Discussion
Like Tree1Likes
Old 23rd June 2012, 18:07   #11
B3-Michael
Garage: Alpina E30 B3 2.7 Convertible, Alpina E30 B6 3.5
@Dave:
Here are the numbers you are looking for:
Federzylinder ALPINA, ET Liste Seite 30 Position 7
  • left 33 52 625
  • right 33 52 624
Federzylinder BMW (M Variante, ab 1992 auch Serie)
  • left 37 12 11 34 449
  • right 37 12 11 34 450
Just in this moment, I am not sure any more, ift the parts belong to the M5 E34 or to the M-Suspension, offered for the "normal" E34. But your garage will be able to check this.
I also had a adress of a company, which can rebuild the dampers. That would cost 500 Euro each... and that does not make sense because the new parts do not cost more in Germany.
Good luck!
Michael
B3-Michael is online now   Reply With Quote
Old 24th June 2012, 20:36   #12
DaveW
Garage: Alpina B10 Bi-Turbo in Macau Blue
Michael, there is some great info in that link, thanks. I suspect the challenge is in finding the right quality hard nylon seals in order to perform a rebuild that would last any length of time but it would be a huge shame to throw away such an expensive component for the want of a few £10 parts.
My route will almost certainly be governed by time available - I'm taking my BT to classic Le Mans at the beginning of July, so must have it ready before then. A new BT or M-Sport strut (or good exchange unit) would seem to make most sense at this point.
Cheers,
Dave.
DaveW is offline   Reply With Quote
Old 25th June 2012, 18:33   #13
DaveW
SO I wrote to Alpina on Friday and had a reply waiting for me this morning - customer service doesn't get better than that!
"Please be informed that the requested shock absorber rear left with level control system (ALPINA part no. 33 52 625) was replaced by BMW spare part 37 12 11 34 449.
In this case, please also replace the rear right shock absorber with BMW part no. 37 12 11 34 450.
*** The holder for the hydraulic line has to be adopted from the used component *** "
All I have to do now is price them up
Cheers,
Dave.
Old 25th June 2012, 19:23   #14
B3-Michael
Hi Dave,
be glad, that the original parts are not available any more for the Bi-Turbo. For the B12 E38 they are - for 1300 Euro each.
Michael
Old 29th June 2012, 21:56   #15
DaveW
A good end to the story . Thanks to Phil Crouch of CPC who was nursing my Alpina through the SLS pipe change, I now have a new MOT - and I didn't have to change the SLS units. IT would seem that after sitting for an extended period, some oil did get past the top seal of the strut and looked wet and messy - bad enough for MOT tester to issue a fail and claim excessive leaking...
After a couple of days of being moved in and out of Phil's garage while I sourced info on replacement struts, Phil noticed there were no leaks on the ground and no fluid was being used and the car held pressure as it should. The strut was thoroughly cleaned and monitored over a few days and apart from a light misting on the insert, no fluid was escaping - it looks as if its in good shape after all.
Got it re-tested and a pass certificate was issued, which is great news. I'll keep an eye on it over the coming days/weeks and months and if it doesn't leak, I'm not going to change it.
What we did have to do and worth mentioning for other BT owners, was attend to some corrosion to the floor of the car above the CATs. My heashield was in very poor shape and in fact fell off last year - I bought a new one and asked Phil to fit it. Trouble was, in the meantime the heat from the CATs accelerated corrosion and a small hole was appearing. A plate was made up, the rot cut out and all welded to perfection - protected and covered by a shiny new heatshield. Check yours too.
Thanks to all who chipped in with help and advice, much appreciated. I drove it home this evening and it felt fine, felt great in fact to have full boost on tap and it still goes like stink
Cheers,
Dave.
Self Levelling Suspension Noise Graeme Hancock E34 M5 Discussion 29 20th June 2012 18:07
E39 Want to buy: Rear Left Suspension Parts... Please HELP! NICEBIMMER Parts / Other For Sale or Wanted 8 17th October 2009 21:44
F/S 1988 E28 M5 new take off self levelling suspension marksv4 Parts / Other For Sale or Wanted 0 8th October 2006 17:15
Power steering and self levelling suspension.... jack880 E34 M5 Discussion 5 2nd October 2004 09:50
Some question about self-levelling suspension Azmir E34 M5 Discussion 6 26th January 2003 11:26
