B5S questions: losing oil and chassis noise - Page 3 - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > BMW M5, M5 Touring, M6 and Z8 Forums > ALPINABoard.com | BMW Alpina Discussion
Like Tree1Likes
Old 21st December 2011, 11:06   #21
Burj323
Garage: Alpina B5S Black
Originally Posted by doctorUAE View Post
Well, the service boys at AGMC have checked the supercharger and didn't find any traces of oil or signs of wear. Also no other oil leaks detected. Positive news for now.
I just did an oil service so I'm in a good position to monitor consumption going forward.
AGMC's opinion was that high performance engines from BMW M or Alpina do consume more oil - they estimated 1 litre every 1500 Km. My oil consumption up until now has been pretty low - nil in fact, but I have been changing oil every 6-7k or so on average. Perhaps this kept things fine. I left the change much longer this time 11/12k.
BTW - Alpina told me one of main reasons for supercharger failure is because often the oil filter from the 550i is mistakenly fitted instead of the one 545i. The 550i filter starves the supercharger . To quote them:
"In some cases the dealership thinks itīs a 550i and fit a filter from the 4,8l BMW-engine (part no. 11 42 7 542 021). This filter fitted in a B5/6/7 doesnīt filter the oil at all, it passes by just the bypass system. The first part which collapses is the radial compressor. thatīs about 90% the reason for radial compressor failures.... It must be BMW part no. 11 42 7 511 161."
Oh my I just found out the oil filter they fitted at last oil service (march 2011, 7,000 km till now) is WRONG! And I doubt all oil filters that have been fitted in my car were all wrong!
The Radial compressor has been replaced once (at 35,000 km). Really don't know what sort of damage could have done to the present one.
I am not happy. My B5S still has a rough clod start every time I frist start it in the morning, with fluctuating idle. And there seems to be too much oil in the engine. Have to park the car at the dealer again for I don't know how many days to get all these sorted!
Burj323 is offline   Reply With Quote
Old 8th January 2012, 07:29   #22
doctorUAE
Garage: Alpina B5s Moonstone metallic
Apologies for the delayed response but I've been travelling... I would push your dealer hard to investigate and definitely push to get Alpina involved in the troubleshooting.
A quick update on my situation. As you know from previous posts in this thread I had AGMC check the compressor for issues and they gave it the all clear. A month or so later the engine light I'd had previously returned. After another large rant from me they took the car in and diagnostics said it was a air/fuel mixture warning.
After a week or so of working with Alpina it was concluded the catalytic converters were the issue and needed replacing. A few days later they phoned with even better news - it turns out the compressor was leaking oil that had in turn damaged the cats. The result - a new compressor AND new cats were required!
When they told me the list price for all the parts, I needed a stiff drink. Luckily, because of the car history and no doubt because they'd given the all clear on the compressor, they gave me 50% off parts and labour. It is still a horrendous number but probably not too bad given the circumstances. Warranty expired Feb last year with not option to extend. 3rd party warranties would not have saved me much.
My guess was that the previous owner made a mistake with the oil filter just before I got it. By the time the filter was changed the damage may have been done.
The pattern leading to this - high oil consumption, warnings etc, does seem to follow your situation but I'm really just guessing. My personal theory is also guess work. It seems many B5/B5s owners have had replacement compressors under all manner of circumstances.
Alpina did warn me about the filter and in my case perhaps it has done for me.
I did consider this failure 'worse case scenario' when I bought the car. Unfortunately it has occurred. However, I console myself with the fact that I got the car at a very good price and the difference with the work is about what I probably should have paid for it. Plus it now has a new compressor which might allay the fears of any future owners.
It still hurts though! (but I still don't regret buying the car in the slightest. I've had some pain but it gives me so much back that I don't resent it. I'm actually picking it up today after 4 weeks in the garage and I can't wait, it's been a long 4 weeks!)
doctorUAE is offline   Reply With Quote
Old 8th January 2012, 14:09   #23
Burj323
Doc.
Thanks for sharing your experience. Sorry to hear the problems you are encountering.
CAT. + Compressor = a lot of money. My SA told me it would cost 20,000 AED for a brand new compressor, part only! And you have to wait for few weeks.
I left my Alpina at the workshop before I took off for a 2 week vacation. Hopefully this would give them enough time to sort out all problems.
Got the email from the SA today for a bit of updates:
1. Fluctuating idling at cold start: all spark plugs need to be replaced and they are waiting for the plugs. ?? I thought the Alpina use the same plugs on BMW 5 series.
2. Oil filter: they told me the oil filter (part no. 11 42 7 542 021) they used was correct. That is the part indicated when key in the chassis number in their system. However they has replaced the old one with 11 42 7 511 161 per Alpina’s instruction.
I have asked them to check the compressor and make sure there is no leak. Luckily my car is still under warranty till Feb 2014. However leaving the car there for weeks is still a big headache.
Old 8th January 2012, 14:40   #24
Hasan Shaikh
Hasan Shaikh's Avatar
Garage: E63 ///M6 - White
The correct oil filter for the Alpina B5 is 11 42 7 511 161.
11 42 7 542 021 is not the correct filter.
Hasan Shaikh is offline   Reply With Quote
Old 8th January 2012, 14:51   #25
Burj323
When I told them they have used the wrong oil filters on my Alpina for the past 50,000 km, they looked at me in disbelief until I showed them the email from Alpina. How can something so simple went wrong?
Old 8th January 2012, 14:57   #26
Hasan Shaikh
Actually that is too complicated for AGMC.
They forgot to tighten the wheel bolts on my friends car when he gave them the car for an alignment and nearly killed him and his family.
Old 8th January 2012, 15:21   #27
Burj323
I have to say Alfardan is far better than AGMC. My question is, the system directed the mechanic to get the oil filter based on the chassis number they put in. And that is a wrong oil fliter which could cause premature failure of compressor, a costly repair. If I don't tell them they will continue to service all Alpina B5/S in Doha the same way.
Old 8th January 2012, 15:34   #28
Hasan Shaikh
I know I have lived in Doha for 3 years.
I believe its a mistake by the tech. He should have used the Alpina chassis number to get the part number. I never had any problem like this with my B5 in Doha.
Old 6th May 2013, 11:08   #29
ASR1
Garage: E39 M5 - Oxford/Caramel (sold)
Anyone know where I can find a good Alpina B5 / B5S to buy in Doha?
BMW E39 M5 - Oxford Green/Caramel Heritage
ASR1 is offline   Reply With Quote
E34 For Sale: E34 M5 Rolling Chassis PorscheH6 Cars For Sale or Wanted 4 9th July 2011 07:08
After losing your M5 for.... Sharpie12 E60 M5 and E61 M5 Touring Discussion 20 21st July 2009 19:58
Possible to swap S85 with SMG into a different chassis? mattyice E60 M5 and E61 M5 Touring Discussion 16 28th June 2009 06:34
Need help - chassis number Demonbiker E34 M5 Discussion 4 23rd March 2007 00:35
Chassis Numbers mblaster E34 M5 Discussion 3 22nd May 2003 08:48
