Alpina b10 bt #260 eml/throttle problem - Page 5 - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > BMW M5, M5 Touring, M6 and Z8 Forums > ALPINABoard.com | BMW Alpina Discussion
Like Tree3Likes
Old 22nd September 2011, 20:28   #41
Henska
Garage: Alpina b10 biturbo#260
Cos i don't know the type of the resistor which is destroyed....that's why i asked earlier in the post the colour of stripes in resistor or ohm value...do you have info about this, Tomba?
Henska is offline   Reply With Quote
Old 22nd September 2011, 20:30   #42
Tomba
Garage: BMW E34 M5 3.6 macaoblau
No, but I am sure another BT owner can have a look for you.
To///Mba
Tomba is offline   Reply With Quote
Old 30th September 2011, 10:25   #43
Henska
Hello!
A new problem has arrived.
Car starts to twtch and powers loss when driving steady throthle... Easier when engine is hot.
Problem occurs in several speed and rpm's not every time in same situation.
But only when steady throttle...when pushin pedal accelerates very fine. Idle is fine also.
I measured lambda when driving and mixture shows very lean in steady throttle..
0,08. When accelerating it raises and correct mixture inabout 0,8,,,,and when dropped to the idle, corrects mixture about 0,2-0,5......
So steady throttle it goes lean.....
-Does my throttle valve brush mod, do this?.how much is your ohms when measuring 6-7&7-8 pins without plug from throttle body?
-Fuel pressure or regulator? Hose has been broken i dont know how long.....but now fixed...
-Ignition? Some candles goes off and nonburning oxygen shows lean in lambda..Pops in exhaust.
Airleak?
Regards
Henkka
Old 30th September 2011, 19:17   #44
Chas C
Chas C's Avatar
Garage: Alpinas
Car starts to twitch and powers loss when driving steady throttle.
I've also experienced this and it's discussed a little on the (long) thread about the BT 'coughing'.
Sometimes it's just a blip - a momentary loss of power - and it's most noticable when cruising on a steady throttle. Ocassionally it's more of a 'jerk' and I've even seen it cause the cruise control to disengage.
Chas
E32 Alpina B3.5 (Alpina Green/Beige)
E34 Alpina B10 BiTurbo #290 (Diamondblack/black)
E36 Alpina B8 4.6 Coupe #015 (Alpina Blue/Blue)
E39 Alpina B10 V8 #003/1 (Scarab/Pearl Beige)
Honda CBR1100XX - something for the weekend, Sir
Chas C is offline   Reply With Quote
Old 30th September 2011, 23:18   #45
Tomba
Hello!
Does it sweep from low (0,1-0,2 to 0,7-0,8) to high during idle and part load when the problem doesn't occure?
Fuel injection main load is the MAF. If your thottle body does wierd things the MAF will measure it and the ECU will adjust injection timing to it. Very unlikely that this could be it.
Could be. Lean mixture could be more air (than measured by MAF) or to less fuel. I was thinking of a clogged fuel filter that suddenly comes up... But its hard to decide from a distance. I would like to see the Lambda-integrator [%] value from the ecu when the problem occurs. Than you can see if th ECU is adding fuel or not. And... compare injection timing [ms] when the problem occurs and not.
Could be it to... Do you know the service history of the car? Changing the spark plugs, filters and fluids isn't a bad idea when you don't know it.
Airleak?
Yes, can be it to. The MAF measured a to low mass flow and the ECU wil adjust injection timing to that. But... most times an airleak is always there and not suddenly there.
One last thing that you might check. Since the problem doesn't occure always and you had some cracked or lose (vacuum) hoses. There is a regulation called active canister control. It is meant to supply fuel damps into the engine instead of atmosphere. A valve is placed between a hose from the canister to the inlet manifold. If that hose is not attached to the canister but freely in the open air it causes an air leak when the valve is activated. The hose goes (If I Remeber Correctly, IIRC) from left/front side of the car to the middle of the inlet manifold.
Ciao
Old 2nd October 2011, 14:26   #46
Henska
A: yes, but when dropped to idle or pushing throttle it sweeps wider range first but then relaxes and sweeps only like 0,7/0,8.
A:Okey.
A: i changed fuelfilter, no effect. I get bosch kts next week so then i can go to the car's brains.
I will post some documents then.
A: All filters,fluids,sparkplugs,MAF,tps,coil,distributor cap,roller and sparkplug wires has been replaced after month ago....
A: sounds reasonable...
A: got to check that...i remember i checked hoses and they were attached but another hose from canister goes somewhere above the canister and can't be seen..i check that...
Thanks again!!
Ciao
H
Old 8th October 2011, 15:56   #47
Henska
Hello,
I just arrived home with my alpina...car twitched on steady throttle like i posted earlier, THEN
I switch lights off and problem disappered!!! Then switch light back on and car started to twitch...and angain lights off and problem disappered...and 20km driving home without problem.......
Cars lightrelay box(the about 10cm x 20cm large) was broken when car was in skyline, he had been putted normal relay to lights....i think that theres some probs with earthing or signals...i don't know is the light relay connected to dme or eml anykind, but weirdly it has effect.
Have to drive without lights so long that i find new light relay box....is that normal bmw stuff? I think it should be....
Henkka.
Old 18th October 2011, 05:56   #48
tunderbolt
Garage: M5 Black
Try replacing the cluster with one from a 535i with eml. I had a phantom problem that took me years to solve and going back and forth with Alpina turned out to be a bad instrument cluster, car now runs like a dream.Was the car imported to the US where is it located?
tunderbolt is offline   Reply With Quote
Old 27th November 2011, 18:29   #49
Henska
Hi.
Car is in Finland.
Imported from germany.
The problem was in alternator....it charged 13,6v then suddenly dropped voltage and raised it again. No signals in dashboard or lights shimmering or anything... I started to think connection of light switch and twitching which dissappered and appered suddenly....
I put fuel pressure gauge in place and get to the road. Fuel pressure was ok. 3,0/3,1 and when pushing 3,5bar.
Everything in ignition side is new.
I don't know the absolute thruth but somehow when voltage from alternator dropped the ignition started to black out. Like traction control started to limit ignition..... That i assume from that when i take the belt off from alternator the traction control light goes on... Does the traction control sense from alternator voltage that engine is running?as like the waterpump relay to turbo's? Well now drived about 1500km's without problems. Very cool car indeed. Today washed it and droved to garage to spend winter holiday.
I thought that in winter i :
change doorhandle seals
Change indoor roof cloth
Put original radio
Adjustable coilovers
Little bit narrow tires and spacers
So i can drop it to ground like i like
And then full brake service cleaning and painting calibers to grey with golden alpina text.
And offcourse lot's of beer and planning and dreaming in the carage....
Old 27th November 2011, 21:25   #50
Tomba
No, ABS/ASC has a separate wire form DME with engine speed. The ABS/ASC sets the warning light on when the power voltage is to low. It will also store an error message related to the low supply voltage.
Pictures!!!
Btw. good to hear it runs as it should be. For the fuel pressure, you need to add the boost pressure + 3.0bar. So when the engine is boosting 0.5bar (1.5 in VDO meter) the fuel pressure must be 3.5.
Buying an 01 E39 M5 - Throttle actuator problem? mjuarez E39 M5 and E52 Z8 Discussion 5 4th January 2011 17:17
Alpina slide throttle (3.0 CSL) eBay Germany Yannick ALPINABoard.com | BMW Alpina Discussion 0 19th September 2007 09:51
Strange throttle problem Cyrus E34 M5 Discussion 8 23rd February 2007 23:56
THrottle Body Problem Joe Lapicki E39 M5 and E52 Z8 Discussion 7 16th April 2002 02:28
Surging problem at steady throttle MFanatic E34 M5 Discussion 7 27th March 2002 21:13
