Press release from Alpina regarding B5 BiTurbo - The Unofficial BMW M5 Messageboard (m5board.com)
Old 8th July 2010, 10:04   #1
kees
Administrator
Garage: magic moderator wand
The finely honed balance between athleticism, comfort and every-day luxury that has defined ALPINA automobiles for decades reaches a new dimension in the BMW ALPINA B5 Bi-Turbo. Five different generations of 5 Series-based ALPINA automobiles have been developed in the last 35 years, revealing to those in the know a unique and exclusive driving experience. The sixth generation draws from the finest ingredients provided by those previous generations to create a mouth-watering palette of characteristics for the most discerning of drivers in the high performance luxury saloon segment.
THE POWERTRAIN – First Class In Both Performance And Economy First introduced in the BMW ALPINA B7 Bi-Turbo, the all-aluminium V8 powerplant endows the new B5 Bi-Turbo with sensational pace. It achieves 507 horsepower (373 kW) at a moderate 5,500rpm, with maximum torque of 700Nm from 3,000 to 4,750rpm. The “Bi-Turbo” appellation refers to the two turbochargers comfortably nestled inside the V shaped 8 cylinder block. They work in parallel, each feeding one of the two cylinder banks. Specially developed for ALPINA in partnership with Honeywell-Garrett, the bespoke exhaust turbines are generously dimensioned. Compared to its super-charged predecessor, this engine configuration delivers more torque over a broader rev range and improves throttle response at low revs. To fully leverage the potential of the engine, ALPINA have optimised the indirect inter-cooling system (air-to-water / water-to-air) with short intake tracts and increased inter-cooler flow. The high-performance cooling package gains its thermo-dynamic efficiency through the use of a large-volume low-temperature inter-cooler, as well as two water-to-air inter-coolers placed close to the engine. The pistons are a high-performance variant developed together with Mahle to
deal with the extreme temperatures and pressures associated with up to 1.0 bar charging and the engine’s 9.2:1 nominal compression ratio. Altogether this results in an impressive specific output of 115.3 horsepower (85kW) per litre and a mean total compression of 20.1 bar.
Direct injection and Double-VANOS contribute to the B5 Bi-Turbo’s class-leading performance in terms of emissions and economy in the super saloon segment: 10.8 l/100km (26.2 Imp. mpg) and 252g/km CO2 (Combined as per the ECE Norm).
TRANSMISSION – The Eight-Speed All-Rounder
Adapted and tested in cooperation with ZF, the advanced SWITCH-TRONIC 8-speed sport automatic transmission sets a new benchmark. With ALPINA’s philosophy the guiding credo, our engineers have spent thousands of development and test hours ensuring that no other performance automatic transmission comes close to providing this level of both comfort and sportiness.
The blend of eight speeds and plenty of torque makes for unparalleled comfortable gear changes with no noticeable interruption to the delivery of power – only the accompanying acoustics and the dynamic rev counter provide feedback as to the workings of the transmission. The 700Nm of torque means the B5 Bi-Turbo excels at gliding along at low speeds in a high gear with minimum revs, benefiting both consumption and comfort.
In Sport mode a completely different character emerges: the transmission is crisp and unmistakably immediate. The innovative single-cylinder step-down (EZA), specially developed by ALPINA for the B5 Bi-Turbo allows for super quick up-shifts in just milliseconds, in spite of the high torque. Depending on the load on the transmission, the injection of fuel into a given cylinder is interrupted for a fraction of a second, creating the required reduction in torque that the automatic transmission needs for the up-shift. The advantage versus the typical timing ******ation are noticeably quicker shifts, and improved thermo-dynamic efficiency due to reduced exhaust temperatures as well as lower fuel consumption. The single-cylinder step-down (EZA) is accompanied by a tone nothing short of spectacular, as each shift harbours a deeply sonorous back-pressure burble.
The Manual mode gives the driver full control over every shift. The SWITCH-TRONIC buttons are ergonomically and aesthetically positioned on the back side of the steering wheel, and can be used by the driver in whatever manner he or she wishes, based on traffic and the roadway at hand. The system also allows for multi-simultaneous down-shifts in fractions of a second, hereby the transmission will skip several gears depending on accelerator loads and revs. In this manner the 8-speed sport automatic transmission with ALPINA SWITCH-TRONIC reveals itself to be multi-faceted and able to provide the proper shift characteristic for any and all situations.
The intelligent coupling of state-of-the-art engine and transmission technologies give the B5 Bi-Turbo strong performance figures: just 4.7 seconds to 62mph (100km/h) are needed, on the way up to a top speed of 191mph (307km/h). Even if the driver is seldom in such a rush: massive braking capability in the form of ventilated high-performance brakes (front: 374mm/14.7in; rear 370mm/14.6in) ensures braking on par with pure-bred sports cars.
SUSPENSION – Excitingly Sporty, Relaxingly Comfortable
The times when “properly stiff” suspensions were seen as a positive handling characteristic are long gone. It remains a fact that a truly neutral set-up, even at the limit, provides the best technical compromise. This is achieved in part through shorter yet very progressive springs and special suspension arms, which in combination results in more camber on the front track.
Together with 20” wheels and tyres, ALPINA have achieved a very balanced and direct chassis set-up, discarding a pure sport-orientated approach for an agile suspension with precise turn-in. The new light-weight 20” ALPINA CLASSIC are shod with the most advanced high performance tyre technology available today.
Making their debut on the B5 Bi-Turbo, the new MICHELIN PILOT SUPER SPORT tyres, which measure 255/35ZR20 at the front and 285/30ZR20 at the rear, provide highest levels of high-speed stability. In addition to improved all-round capabilities, these non run-flat tyres provide greater traction on wet roads, offer improved hydro-planing behaviour and excellent rolling comfort.
To fulfil the highest demands in terms of comfort, everyday usability and razor-sharp handling when called for, the B5 Bi-Turbo is equipped with electronicallyadjustable suspension (Variable Damper Control). Using the control switch mounted to the left of the shift lever, the driver can select between Normal, Comfort, Sport and Sport+. This system has been artfully calibrated by ALPINA, and is tied into other system parameters controlling steering assistance, torque cushioning and DSC. The B5 Bi-Turbo transitions effortlessly from cultivated luxury to thorough-bred sportiness. Light steering, ultra-comfortable suspension and an imperceptibly shifting transmission B5 Bi-Turbo the ideal partner in stop-and-go traffic, when covering great distances or when encountering less than perfect road surfaces. Yet at the touch of a button, the B5 Bi-Turbo will track through tricky corners and exciting sections of road with an agility and light-footedness like no other in its class.
When the 8-speed sport automatic’s manual mode is combined with the selection of the Sport or Sport+ modes, the driver benefits from a new feature: no mandatory up-shifts. When truly pressing on through twisty sections of road or around hairpins, skilled drivers can remain in their selected gear and not be interrupted by an up-shift.
The optionally available Dynamic Drive reduces body roll in corners, awarding the B5 Bi-Turbo even more agility.
When placed in Sport+ mode by the driver, the B5 Bi-Turbo’s dynamic control systems offer a heightened form of DSC called Dynamic Traction Control (DTC), which allows noticeably more slip at the rear wheels and delays the point at which the traction control systems take over.
DESIGN & INTERIOR – Classic Craftsmanship Meets Modern Technology
The new B5 Bi-Turbo presents typical ALPINA virtues and design cues in a new and convincing fashion, with a refreshing and dynamic appearance.
The self-assured and powerful front commands attention with its decidedly sport-orientated lines and striking air. The rear is especially harmonious, clearly communicating the B5 Bi-Turbo’s ALPINA family heritage. The ALPINA exhaust’s two double-ended-pipes are artfully integrated into the rear valance, a discreet rear diffuser completing the silhouette. The diffuser can be deleted as needed, should the customer desire the optional ability to tow a trailer. In combination with the rear spoiler, the B5 Bi-Turbo’s total aerodynamic package yields the highest levels of safety and stability, especially at high speeds. The resulting reduction in lift, speed-dependent, can reach a remarkable - 60% front and - 30% rear.
The interior reveals the expected discreet touches that suggest the B5 Bi-Turbo’s exclusive pedigree. The standard equipment level is comprehensive: leather interior, versatile and adjustable Comfort seats, an excellent navigation system with Bluetooth preparation, and Xenon headlamps all ensure the driver’s and passengers’ well-being. The hand-stitched LAVALINA leather SWITCH-TRONIC steering wheel can be positioned exactly as needed to see the blue ALPINA gauges with black-panel LCD technology, thanks to the electrically-adjustable steering column. The classic ALPINA burled Myrtle wood trim provides a warm ambience - found only on the USA’s Pacific Coast it is cultivated from dedicated Laurel tree groves grown for just this purpose.
THE BMW ALPINA B5 BITURBO – Brilliantly Balanced High Performance
The overall harmony and the accomplished manner with which the B5 Bi-Turbo’s last fine calibrations were achieved are a common thread, and as always carry that ALPINA flair, our signature. Sovereign performance and opulent torque assure excellent performance, this in conjunction with “best-in-class“ fuel economy and CO2 emissions. Neutral turn-in and road-holding, agile handling and a many-faceted, adjustable suspension satisfy the highest demands in terms of comfort and a sporting nature. The interior’s warm ambience and modern treatments foster a sense of well-being. For those who would only award themselves that something unique, exclusive volumes and the ALPINA philosophy of hand-craftsmanship offer a nearly endless spectrum of personalisation.
File Type: pdf BMW_ALPINA_B5_BITURBO_PerformanceDiagram_EN.pdf (109.6 KB, 53 views)
File Type: pdf BMW_ALPINA_B5_BITURBO_PressInfo_EN.pdf (756.4 KB, 70 views)
kees is offline   Reply With Quote
The Following 5 Users Say Thank You to kees For This Useful Post:
135ti (9th July 2010), BMW Alpina (8th July 2010), Gustav (20th July 2010), Kyle (8th July 2010), Taipan (8th July 2010)
Old 8th July 2010, 10:15   #2
BMW Alpina
BMW Alpina's Avatar
Garage: Alpina B7 Alpina Blue
Amazing that Alpina find a way to make a Twin Turbo configuration
have better low rev throttle response than SuperCharger !
BMW Alpina is offline   Reply With Quote
Old 8th July 2010, 10:46   #3
BMW Alpina
BMW Alpina's Avatar
The Wheel and Tyre Size is interesting compare to the current B7
The B5 have 8.5 x 20 front wheel while the B7 also had the same 8.5 width but 21 inch diameter wheel.
Still the tyres size is bigger for the B5.
B5 use 255/35/20 while B7 use only 245/35/21...
I always thought that the B7 should use a 255 instead of 245 upfront...
I also notice that the current B7 wheel is smaller in width than the previous generation wheel...
wonder why they do that to the B7...
On the rear the B7 have larger wheel (width) at 10inch compare to B5 at 9.5in
although they both have the same 285 size and 30 profile tyre...
That mean B5 should have little bit smaller contact patch at the rear compare to B7
but B5 have larger contact patch at the front compare to B7...
This is interesting since I think the B5 should have bigger contact patch at the rear compare to B7
since it is lighter but with the same engine power and closer gearbox ratio,...
and B7 should have bigger contact patch at the front because it is heavier than the B5...
Turn out it is the opposite of what I thought...
well of course Alpina engineer must have their own reason for this configuration...
Old 9th July 2010, 00:32   #4
Kyle
Kyle's Avatar
Garage: Black E60 B5
Thx for sharing Kees!
I have attached a graph comparing the 3 generations of B5 performance stats.
Interesting! The new motor produces more power much earlier, especially in the torques! By 2500 rpm the motor nearly outputting max torques!
In my B5, max torques is not until ~4000 rpm! If I'm not mistaken in my calculation that is ~37% decrease in rpm to max torques!
I definitely felt this during my test drive at Goodwood but it was hard to put in words! Graphs say it all!
Press release from Alpina regarding B5 BiTurbo-bmw_alpina_b5_performancediagram_en.jpg
Kyle is offline   Reply With Quote
The Following 2 Users Say Thank You to Kyle For This Useful Post:
Gustav (20th July 2010), schlumpf-nu (9th July 2010)
Old 9th July 2010, 00:38   #5
BMW Alpina
BMW Alpina's Avatar
and somehow I think Alpina already had plan to increase the HorsePower and Torque even higher when
they release the B5s version of the F10 few years from today...
Old 17th July 2010, 09:42   #6
graham4242
graham4242's Avatar
Garage: e60 B5s
That torque curve is nuts. The B5S take off at any low revs but the new one is going to be even more impressive.
graham4242 is offline   Reply With Quote
Old 20th July 2010, 23:44   #7
Gustav
Administrator
Gustav's Avatar
Garage: BMW M3 DCT Sedan / Limousine
Also you should take into account the 8 speed gearbox coupled with direct fuel injection that does not kill the spark when upchaning gear: a good performancegain right there.
Webmaster Google+ LinkedIn Facebook Flickr
At your service: comments, suggestions or feedback: gustav@gtboard.com m5board Member visiting Stockholm, Sweden? PM me to and I'll show you Stockholm! gtboard.com
Gustav is offline   Reply With Quote
HD video: BMW ALPINA stand Frankfurt 2009: BMW ALPINA B7 BiTurbo, B3 BiTurbo Allrard, D3 BiTurbo and ALPINA B6S Coupe as well as B6S GT3 Gustav ALPINABoard.com | BMW Alpina Discussion 6 23rd September 2009 18:18
HD Geneva: ALPINA B6S GT3, ALPINA B3 BiTurbo Allrad, ALPINA B7 BiTurbo and ALPINA D3 BiTurbo Gustav ALPINABoard.com | BMW Alpina Discussion 1 9th June 2009 22:19
Press Release 1: World premiere of the new BMW M5 (summary of all press releases) Gustav Most Memorable Threads' 0 4th July 2004 21:13
Press Release 1: World premiere of the new BMW M5 (summary of all press releases) Gustav E60 M5 and E61 M5 Touring Discussion 0 4th July 2004 21:13
UK Press Release for the ALPINA B7 fastsaloons GTBoard.com: General Sportscars 2 28th June 2004 19:46
