Hi Adam ,
Would say that M3 and B3 quite different cars really even though they're both 6 cylinder E36's .
Obviously the engine is the main thing . One 'M' , the other a more highly developed mainstream
unit .
B3's available with 4 body types , manual and Switchtronic as well .
As far as water pumps go , then thats a general E36 trait and I would recommend changing every
100,000 kms as a precaution . Also the radiator .
Suspension bushes are also 'weak' and benefit from upgrading when changed .
Interior trim on E36's generally can be flimsy , with one or two rattles , but it's not too
difficult to sort out .
Rust can be a killer of course . Bottom of the doors , around the rear wheel arches , bottom
edge of boot lids , around the windscreen . Check the sills too because they can get filled
with road rubbish and rot from the inside .
Otherwise they're fairly much bulletproof too .
Buy the best one you can afford , rather than buy a cheaper one with the idea to fix the problems
yourself , as you can often find more wrong under the surface .
Driving wise , They're both obviously quick , the M3 is more 'sporting' where the B3 is more
'understated' . To get the M3 going you have to use more revs , where the B3 has better lowdown
torque .
Handling is similar , although the M3 is harder , but the B3 isn't too soft to be able to throw it
around .
Fuel consumption is better on B3 . You should get 9.5/11.5 l/100 from the B3 under 'normal'
use , the M3 11.5/13.5 l/100 , although both it's possible to get better (or worse !! haha)
I would have no hesitation buying a higher milage car as long as it is supported by a
completely documented history to make sure everything has beeen done properly .
That's an essential .
I've had 6 E36 6-cylinder cars , and all of them had well into 200,000 kms .
My last one was a Schnitzer S3 with 290,000 kms which I had owned from new , and
it ran sweetly all the way though it's life with no problems at all (appart the usual
wear and tear)
Hope some of this is useful and helpful .
Good hunting .
Chris
