Sooner or later I was bound to bump into this issue...so I'd appreciate some views on how to address this issue in the Alpina-Archive (
Alpina-Archive — The Unofficial BMW Alpina homepage - since 1998 — Latest Additions).
There's lots of variants of what can happen to a car over time.
I'm thinking of history such as fitting non-original parts.
In each of the following scenarios when do you consider that an Alpina has stopped being an Alpina?
1. Car with no 'history'
2. Car with engine rebuild by Alpina using original Alpina replacement engine block (but not the original engine block)
3. Car with engine rebuild by an independent using original Alpina replacement engine block (but not the original engine block)
4. Car with engine replaced with replacement engine sourced from another Alpina of the same model
5. Car with engine replaced with replacement engine sourced from another Alpina of a different model
6. Car with engine replaced with BMW engine complimented with Alpina parts from the original engine
7. Car with heavy crash damage - large part of the chassis replaced by new BMW parts
8. Car with heavy crash damage - all Alpina parts moved from original chassis to brand-new chassis
9. Same as 8 but with a used BMW chassis
10. Car is stripped of Alpina parts during theft and rebuilt
11. Car is stripped of Alpina parts and the Alpina papers are sold on. This is used to build an Alpina 'from scratch'.
12. Car is imported to a country with enormous import taxes. The Alpina chassis number is removed and replaced with a BMW chassis number of an already registered local car.
13. Same as 12 but moving all the parts from the original undamaged car to a locally registered BMW.
