oil cooler for B8 - BMW M5 Forum and M6 Forums
post #1 of 36 Old 17th July 2009, 09:32 PM Thread Starter
schlumpf-nu
schlumpf-nu's Avatar
Smile oil cooler for B8
Hay friends of the B8,
we you know has the B8 not an oil cooler, we have themselves the trouble made a kit together to set.
The oil cooler with trunk circuit and all attachments are about 320 euro. This sentence consists of:
- Oil coolers with retaining set suitably for the water cooler M3
- 2 hose lines with special press nipple
- small articles such as O-rings and clammy ones fasten the nipple.
The hose lines consist of VA special press nipple and teflon hose with VA coat, temperature to 150°.
Thus the trunk circuit fits like an original trunk circuit, adapted on our conditions.
Also we would like to refer to it; we will sell this kits as racing parts, without calculation and without warranty.
You must be you in the clear, the B8 has no transmitter feeders for the oil level in it.
Also must be waiting after the installation of the oil cooler, until the thermostat leaves the first time oil into the radiator.
Whereupon the oil level must be stopped correctly.
With an oil change one does not need to make this Prozedere any longer, the oil in the radiator not with is discharged.
The first Kit's could be supplied with to at the beginning of of August.
With interest ask pn at me; also to the planning, since the press nipples and oil cooler must be ordered.
__________________________________
i need the dollar, yes i need ...............
Many greetings from in Bavarian Swabia, the B8 convertible headquarters
schlumpf-nu
schlumpf-nu is offline
post #2 of 36 Old 18th July 2009, 10:55 PM
Danish
Carguy
Danish's Avatar
This looks very interesting Thomas. Do you know how much this will decrease oil temperatures in normal driving?
Michael aka B8 Guru
2003 BMW M5
1998 BMW ALPINA B8 4.6 Cabrio
1995 BMW ALPINA B12 5.7 Coupe
=== A L P I N A B125.7 C L U B ===
Danish is offline
post #3 of 36 Old 18th July 2009, 11:51 PM
Ferrari-Bmw
On my cabrio ,, 100°c is easy after 2 rounds on the Nordscleife
I think i have never been able to see 70+ on my BT ....... even after high speed runs ,,
but i could be wrong
Sveinbjörn Hrafnsson
E30 CABRIO V12 M70B50 ///
ALPINA B10 BITURBO 346 @ 507
E34 550 V12 JML
http://alpina.123.is/pictures/
Ferrari-Bmw is offline
post #4 of 36 Old 19th July 2009, 09:15 AM Thread Starter
schlumpf-nu
Without oil cooler
- Outside temperature of 26°
- Oil temperature 115°
- 220 km/h - 240 km/h
measured by me by a convertible
with oil cooler
- Outside temperature of 27°
- Oil temperature 90° in the town
- Oil temperature 105° on the highway
- 280 km/h
measured by Martin with a B8 coupe
BMW ALPINA-Forum
schlumpf-nu
post #5 of 36 Old 19th July 2009, 09:19 AM Thread Starter
schlumpf-nu
if I have the tube sentence ready, I will put a few pictures again.
Oh, I see, additional oil amount approx. 0,5-0,6 litres
schlumpf-nu
post #6 of 36 Old 19th July 2009, 11:15 AM
Ferrari-Bmw
Originally Posted by schlumpf-nu View Post
Without oil cooler
with oil cooler
- 280 km/h
280 km vs ~~~~230 is a heavy gain even if the temp is just 10°c in difference,, with the cooler,, is it belt-driven or electric
but 90°c in town is A LOT imo... when i was cruising from Nürburgring to Denmark in middle of May on my Cabrio.. i saw 80-100 °c depends on the speed,, i do not have a oil-cooler but i am saerching for Z3M differental-kappe
it is funny to see like on the BT and you are cruising,, and then decide to have a blast ,, and watch the gauge ,, okey ,, then floor the car ,, how engine oil and diff oil gets higher after a while
E34 550 V12 JML
post #7 of 36 Old 19th July 2009, 03:11 PM
Danish
Carguy
Danish's Avatar
First of all, a big applause to Thomas for (once again) contributing significantly to the B8 community
It is great with some data, but the measurements should be made on the same car in order to be valid (or at least the same body style). I have seen great variance between same day / same route engine oil temperature between my Coupe, Touring and Cabrio (s). Why it is this way, I am not sure. It can be that there is a true difference or that the VDO gauges have significant tolerance
With this oil cooler, how much extra oil is left in the system after a normal oil change?
Without oil cooler
with oil cooler
- 280 km/h
BMW ALPINA-Forum
Michael aka B8 Guru
2003 BMW M5
Danish is offline
post #8 of 36 Old 19th July 2009, 04:52 PM Thread Starter
schlumpf-nu
0,5-0,6 litres
Hello Michael,
the flowers belong not only to me alone, Martin a member in the German forum ALPINA, had started running the first cooler.
Together we have thought up this solution. A Plug in Play solution, without sweat work etc.
The temperatures were also confirmed by other B8 driver.
There will be a good one divergence, however how high is this?
Why does every other ALPINA have an oil cooler? My B6 3.5, B5 and also the B10 BT, everybody has an oil cooler.
The place between oil cooler and front Stabi is the problem, here fits nobody original tube sentence, there is not this place.
Hence, we need the Specially Pressnipples.
In the beginning of the next week the first management sentence will be ready, then put I pictures again.
schlumpf-nu
post #9 of 36 Old 19th July 2009, 11:18 PM
Dirk BT
Dirk BT's Avatar
Sveinbjörn, we are talking about the engine and not the rear diff
Dirk BT is offline
post #10 of 36 Old 20th July 2009, 01:01 AM
Ferrari-Bmw
hehe,, i think i want the earth to swallow me,,,,,,,,
i dont know how i misunderstood this
E34 550 V12 JML
Potential Oil Cooler GB mottati M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 110 24th August 2010 07:28 PM
Need an oil cooler for my M5 Rallistas E39 M5 and E52 Z8 Discussion 2 27th September 2007 06:39 AM
cooler temps are OKAY with me... Brooklyn M E39 M5 and E52 Z8 Discussion 4 25th August 2007 12:02 PM
oil cooler thermostat m1008cucv E34 M5 Discussion 1 31st May 2006 06:27 AM
B6 2,8 oil cooler? carmel ALPINABoard.com | BMW Alpina Discussion 10 25th May 2001 02:24 PM
