Old 10th June 2009, 02:46   #1
stephenperry
Garage: Alpina B10 3.3 in Estoril Blue
EEPROM-KI Message on E39 B10 3.3 Instrument Cluster
I do my own servicing and recently bought a copy of CarSoft 6.5 along with an interface off eBay with the intention of replacing my trusty Draper service reset tool. Finally got a chance to use it at the weekend after performing a brake fluid change and Oil Service, it worked as it should and reset the service lights and brake fluid light as anticipated.
Out of curiousity I scanned for existing fault codes, and found a couple which didn't seem anything major, so I cleared them to see if they would return at a later date.
Now for the fun part.... I found a menu entitled Vehicle Coding E38/E39, which listed settings like KM or Miles, language settings like English (UK), (US) etc. and the bit that I was interested in - "Automatically lock doors when driving". I clicked the button for READ DATA, and it populated the list with incorrect settings - Germany, Litres, KM etc. I set them to the correct values, along with the box for auto-door locking and clicked the button to WRITE DATA....
It ran through the process, which took a couple of minutes, apparently successfully, and said that I should turn the ignition off for 10 seconds, which I did.... turning it back on.... I got a message EEPROM-KI in the OBC part of the cluster and the following symptoms...
  • Rev counter flicks up momentarily when engine starts (like an electrical "blip") then drops to 0 and does not move at all.
    MPG counter is completely bananas - twitchy and jumps around all over the place, completely off the scale at times.
    OBC button is completely inoperative, no display on OBC (although CHECK CONTROL OK appears when pressing the right hand stalk, and the cluster sweep test performs as expected), no display on OBC/radio panel either (although the radio display and buttons work there are no OBC functions available or displayed)
    Speedometer reads too fast for the road speed - an indicated 39mph is a true 30mph (verified by GPS)
    Driveability, engine temperature guage and fuel guage all appear normal and unaffected so far, as does the mileage counter.
Hindsight is a wonderful thing, I've got bruises from kicking myself so hard Question is, what should I do now? I tried the cluster reset procedure and it didn't make any difference, I've also tried rerunning the CarSoft procedure a few times, again no difference, I've also tried disconnecting the battery and leaving it overnight, but it's still the same.
I've got it booked into the local BMW dealer next week, but since it's an Alpina cluster (with the 200mph clocks) would that make a difference to what they could or couldn't do to fix it? Does it sound fixable or does it sound like I'll need a new cluster? Can anyone recommend a company who've dealt with these problems before?
A very worried B10 3.3 owner....
stephenperry is offline
Feedback on EEPROM-KI error message? GreekM5 E39 M5 and E52 Z8 Discussion 17 8th July 2008 19:24
E39 M5 instrument cluster! Norm Off Topic Forum 0 2nd September 2003 12:50
WTB E34 M5 instrument cluster..... PPHILPOT E34 M5 Discussion 9 26th April 2003 04:44
Help - '95 M5 instrument cluster Grant E34 M5 Discussion 9 17th February 2003 06:40
New instrument cluster. Streetking E39 M5 and E52 Z8 Discussion 16 13th December 2002 18:54
Page generated in 0.09623 seconds with 11 queries
