Old 1st February 2002, 17:58   #1
Andy G
Garage: e23 B10 Lapis Blau,
Send a message via AIM to Andy G
Old E3 Alpina
I like the old E3's, and have read about the 'few' Alpina versions.
The senior six register in the US has a couple on their books, and here's their page that shows they did exist.
http://www.seniorsix.org/photos/davebeddows_alpina.html
It looks very smart on it's Alpina rims.
Andy G is offline
Old 1st February 2002, 19:12   #2
kees
Administrator
Garage: magic moderator wand
The early Alpinas are very cool and very exclusive...
Would you believe that the current owner bought that car for 700 US dollars?
Kees
kees is offline
Old 1st February 2002, 21:17   #3
raymondw
raymondw's Avatar
Here is an article about the 3.0 Si. Courtesy of the www.cs-zone.com.
Raymond
ALPINA-CONVERTED BMW 3.0 Si SALOON
BAVARIAN BOMBSHELL
(Autocar, 29 March 1973. By A.D. Shanks. UK.)
There exists in Europe an elite of tuning companies who, with the assistance of the manufacturer of the car of their choice, are able to concentrate exclusively on producing high performance versions of just one make of car. One thinks immediately of Abarth in conjunction with Fiat, of Broadspeed with Ford, and Daniel Richmond of Downton fame in conjunction with British Leyland, and in the case of BMW, the name of Alpina has become universally renowned.
This enterprising German company, that started life in a sewing machine-shop, can be justifiably proud of their position as the biggest supplier of tuning equipment for the BMW range of cars. But unlike most other tuning companies, Alpina have the problem that BMW already produce their own high performance version of each of their model ranges. It has become necessary therefore, for Alpina to go very considerable trouble to improve on the factory article.
This is particularly so with the 3.0 Si saloon which we have been fortunate to have the use of recently. In standard form, this five-seater saloon is already capable of accelerating from rest to 100mph in only 20.8sec and has a maximum speed in excess of 130mph, and some would surely argue the necessity of improving on these already most impressive figures.
The answer that Alpina have come up with is both radical and expensive, and Alpina have not spared anybody’s reputation in getting to what they consider to be the ultimate in a road-going BMW saloon.
Gone is the computerized Bosch fuel injection, to be replaced by the simpler mechanical Kugelfischer system, with its priceless virtue of being adjustable. Gone also, are the famous triple pot combustion chambers, in favour of a hemi-head design that is more in keeping with the quest for sheer power. The standard clutch has also been replaced by a heavy-duty unit, and the thickness of the disc brakes has also been increased in the light of the increased performance potential.
So much for the items that have been replaced, what of those that have required only alteration? Starting with the engine in addition to the combustion chamber changes, the valves and ports are altered, while the compression ratio has been increased from 9.5 to 10.5:1. A 300 deg overlap camshaft and an enlarged diameter exhaust system complete the underbonnet work. The suspension is altered considerably at both ends of the car, most noticeably at the rear. Stronger springs and Bilstein dampers are fitted all round, and slight negative camber at the front is combined with considerable negative camber at the rear. The anti-roll bars are adjustable over a large range, and it is therefore possible by adjusting the roll stiffness at either end of the car to tailor the handling characteristics to one’s own taste.
The remaining items of the Alpina package are a set of beautifully-made 7 in. wide magnesium wheels which carry massive 195/70-14in. Michelin XVR tyres, a neat black glass-fibre “bib” front spoiler, a limited-slip differential, an electric fan, a higher final drive ratio of 3.25:1, and the engine is rev-limited at 7,100rpm, instead of the 6,500rpm rev-limit of the standard 3.0 Si.
On the road, the Alpina 3.0 Si displays the same Jekyll and Hyde characteristics as the standard version, only more so. Despite the extensive engine tuning necessary to gain an increase from 200 to 250 (DIN) bhp, there is a total absence of any temperament even after prolonged running in slow moving traffic, and the engine is ever ready to pour out its effortless performance at the slightest bidding. But it is on the open road that the car really comes into its own.
At 70mph a changedown to third gear enables one to rocket up to 100mph in under nine seconds when a change to top gear can have 120mph showing in only a further 14 seconds. This kind of performance is usually associated with cars of twice the capacity of the BMW, very few of which can rival the five-seater comfort of this saloon. The cost in terms of petrol consumption is not as heavy as one might imagine, our overall consumption of 18.4mpg is remarkable for a car of this performance and size.
The responsive handling of this very large car was a revelation. There is a taut feel to the whole of the suspension, and while this gives a harsh ride on indifferent roads or at low speed, as the speed builds up the firm, well-damped suspension instills considerable confidence in the car’s ability to cope with any combination of surface, or irregularity. The delightful thick-rimmed steering wheel reduces minor changes in direction to a mere flick of the wrist. The neutral handling can be changed to oversteer at will, and within limits, the application of any amount of power can be balanced by the quick steering.
It is hard to believe that the steering is power-assisted, as the amount of feel that is transmitted to the hands is just right. It is only after effortlessly manoeuvring this very large car into a tight parking space that one realizes that one is not solely responsible for the results.
The gearbox of this Alpina version shares the same internal ratios as the standard 3.0 Si, but the fitment of a 3.25:1 rear axle ratio in place of the 3.45:1 unit of the 3.0 Si, gives a worth wile decrease in engine speed at fast cruising speeds. It is important to make the point that the impressive acceleration of the Alpina is not the result of sprint gearing. The car is quite capable of cruising all day in excess of 120mph with a marked lack of noise or fuss. Although the gears are widely spaced, the wide power band of the engine effectively masks the gaps. The only criticism that we would level at the gearbox concerns the considerable rattle from the layshaft. This is most noticeable if any attempt is made to accelerate strongly in third or top gears from less than 1800rpm, and prevented any attempt to take acceleration figures in top gear from 20mph. While praising the gearbox as fitted to the test car in general, we would certainly like to be first in the queue when a close-ratio five-speed gear box becomes available.
Like the Bosch petrol injection of the 3.0 Si, the Kugelfischer system fitted to the Alpina does not have any form of mixture enrichment, and to start up the car, you simply turn the key. After a few preliminary sputters, the engine will usually catch, but the precaution must be taken of avoiding wide throttle openings during the first half minute of running. What one must never do is to touch the accelerator when starting the car, whether the engine is hot or cold. Our experience suggests that the injection tuning is critical for easy starting.
The standard 3.0 Si seats are comfortable enough, but lack sufficient lateral location to cope with the extremely high cornering forces that this car is capable of producing. In addition, the test car was fitted with inertia reel seat belts, which prevent one from strapping oneself in tightly. The omission of proper bucket seats on a car of this character, not to mention price, seems curious. In all respect of comfort and appointments, the Alpina version is well up to the high standards of the normal 3.0 Si, the spacious interior providing more than enough room for four or five adults and their luggage.
To put the performance of this car into perspective, one must look to the real exotica of modern cars to find any that are as fast either in top speed or acceleration. It is for instance identical in performance to the Jensen SP and faster than the 300SEL V8 Mercedes-Benz. The acceleration from rest to 60mph is identical to the Morgan +8, and the top speed is some 20mph faster than the Jaguar XJ6. Perhaps the most striking comparison of all is against the Maserati Bora which is only two tenths of a second faster to 60mph, and less than two seconds faster to 80mph.
Of course, such performance does not come cheaply. The cost of the complete Alpina package adds £2,700 to the cost of the standard car, bringing the “show-room” price up to few pence under £7,000.
However, it is possible to buy the units that make up the conversion as a number of separate items. The suspension parts can be bought over the counter from the concessionaires, and will shortly be available from a selected few BMW dealers around the countryside. BMW insists that they must carry out the fitting of these parts.
At the present time, the Alpina 250bhp engine must be built up and fitted by Alpina in Germany before the car is imported, so there is an element of import duty included in the cost of this item. An alternative that might appeal to some is to have the 3.0 Si engine “blueprinted” in this country. The final result may not be as electrifying as the modified engine, but a worthwhile gain of 10 per cent is talked by the concessionaires.
In conclusion, the point must be made that the Alpina 3.0 Si is a thoroughly practical proposition, and while we have dwelt on the performance that the converted car offers, this is not gained at the expense of any noticeable loss of flexibility, nor any reduction in the standards of road behaviour of the standard car.
PERFORMANCE CHECK
Maximum speeds
Gear
mph
km/h
rpm
Alpina
3.0 Si
Alpina
3.0 Si
Alpina
3.0 Si
132
225
213
7,200
6,400
3rd
104
93
167
150
7,200
6,250
2nd
65
62
104
100
7,200
6,500
1st
37
35
59
56
7,200
6,500
Standing ¼ mile
Alpina: 15.3sec (94mph)
3.0 Si: 15.7sec (89mph)
Standing kilometre
Alpina: 27.9sec (117mph)
3.0 Si: 28.7sec (111mph)
Acceleratie 0 - … mph, time in seconds
30
40
50
60
70
80
90
100
110
120
Alpina
2.6
4.0
5.3
6.7
9.1
11.8
14.6
17.8
23.4
31.4
3.0 Si
2.8
4.2
5.8
7.4
10.0
12.9
15.9
20.8
27.3
37.0
Speed range, gear ratios and time in seconds
top
3rd
2nd
mph
Alpina
3.0 Si
Alpina
3.0 Si
Alpina
3.0 Si
10-30
5.6
3.3
3.4
20-40
8.5
7.8
5.4
5.1
2.7
2.9
30-50
8.4
7.2
5.2
4.7
2.8
2.6
40-60
7.2
7.1
5.0
4.6
2.9
3.1
50-70
7.4
7.7
4.9
4.8
60-80
8.3
7.9
5.0
5.3
70-90
8.5
8.7
5.1
6.1
80-100
9.1
10.0
6.0
90-110
9.8
12.6
FUEL CONSUMPTION (Overall)
Alpina: 18.4 mpg (15.4 litres/100km)
3.0 Si: 17.4 mpg (16.2 litres/100km)
BACK
raymondw is offline
Old 1st February 2002, 22:22   #4
JetBoy
JetBoy's Avatar
Garage: .
Send a message via MSN to JetBoy
Hi !
I knew I had seen that exact car 1- 2 years ago. It is also in http://www.nolimitz.com/Alpina_b7/rally.htm Remenber ?
The world is too small sometimes.
You can almost have lunch in its engine, Wow:
JetBoy is offline
Old 5th February 2002, 12:15   #5
B9boy
Garage: AlpinaB9 E28 Polaris Silver
I've got an original brochure of the ones sold in England somewhere with a couple of press shots, I try and dig it out.
That’s one lovely car in the Seattle rally must surely be rare now
How much do these go for?
B9boy is offline
Old 5th February 2002, 13:52   #6
Andy G
Is it an Alpina brochure? If so then 'Wow', If you can find it, may I have a coloured copy?
Obviously I'll pay for all expense.
Cheers
Andy G is offline
Old 5th February 2002, 14:17   #7
B9boy
The brochure is a collection of sheets in a clip folder listing bolt on options, spoilers and the complete cars offered with a picture on the front and the text on the back. Ill try and get it copied this week and let you know the damage. What do you drive??
B9boy is offline
Old 5th February 2002, 14:21   #8
Andy G
an M3 saloon, not an Alpina unfortunatley, but hey, it's early in the year, so you never know whats round the corner! I take it you have a B9! whats the spec?
Andy G is offline
Old 5th February 2002, 14:35   #9
B9boy
Standard 245bhp but its suposed to be the last uk car built, hows your Ford in the garage
B9boy is offline
Old 5th February 2002, 15:58   #10
Andy G
well well, small world, it's still there! hows tricks Mr P?
I should have guessed really, Surrey etc.
Andy G is offline
Alpina manuals greg1234 ALPINABoard.com | BMW Alpina Discussion 10 31st January 2003 00:47
Alpina Upgrades for a stock Bimmer? OPTIMO ALPINABoard.com | BMW Alpina Discussion 13 7th March 2002 16:48
Alpina B8 nuts in Japan! Gustav ALPINABoard.com | BMW Alpina Discussion 20 14th January 2002 18:01
ALPINA Meeting 2001 on Nürburgring Danish ALPINABoard.com | BMW Alpina Discussion 6 18th May 2001 23:35
Alpina wheels multi-spoke design or not ? MTY ALPINABoard.com | BMW Alpina Discussion 8 15th March 2001 10:43
Page generated in 0.21137 seconds with 11 queries
