Old 18th August 2008, 12:18   #1
Trotto
Trotto's Avatar
Garage: Alpina B10 Biturbo, BMW Black
B10 Biturbo slightly lower rear right
I've noticed the car is slightly lower on the rear right side than the rear left side. It can be seen as the wheel well creeps closer to the wheel on the right side. There are also marks on the inner wheel well from contact with the wheel, and the wheel has marks of course.
I can't see any leak on the dampers...can it be worn springs. or some fault in the self levelling system?
Trotto is offline
Old 18th August 2008, 18:30   #2
DaveW
Garage: Alpina B10 Bi-Turbo in Macau Blue
Could be tired suspension as you suggest.
The SLS can only really be measured with the engine running and after a short drive - it needs to be pressurised.
Each SLS leg should raise or lowe the rear by the same amount (spheres ok?) so if it's down one side it could be a leak on that side, faulty sphere or weak spring.
As for the lateral movement, that sounds like subframe bushes - when I go to the Ring, I can feel quite a bit of elasticity at the rear and the wheel will make contact with an inner arch if I push it enough - renew the bushes if your very worried.
Other than that, you need a specialist and a ramp!
Cheers,
Dave.
DaveW is offline
The new 7-series: official pictures Gustav GTBoard.com: General Sportscars 95 16th August 2008 01:25
M5 rear lower control arm more stout than 540i's basil E39 M5 and E52 Z8 Discussion 0 11th September 2003 07:18
Article: Sport Auto E34 B10 Biturbo vs Testarossa Dirim ALPINABoard.com | BMW Alpina Discussion 2 29th January 2002 03:56
Posted Alpina B10 BiTurbo Articles Dirim ALPINABoard.com | BMW Alpina Discussion 29 19th January 2002 17:55
B10 BiTurbo and B12 performance? Xipe ALPINABoard.com | BMW Alpina Discussion 25 15th January 2002 12:41
Page generated in 0.08714 seconds with 11 queries
