ALPINA B10 BITURBO (BT, Bi-Turbo) BRAKE REPLACEMENT THREAD
This thread is intended to group the main approaches to replacing the BiTurbo's brakes in one thread for ease of searching and discussion for current and future BiTurbo owners. Please discuss and add any information as you see fit.
B10 BiTurbo original size front brake discs:
332mm x 32mm. The Alpina caliper is made by Lucas-Girling and is a 4-piston cast iron caliper. The calipers are very strong. Being made of cast iron however, it retains heat during continuous hard driving. The issue has been to find a more affordable front braking solution without the cost of Alpina discs and Alpina brake pads.
There have been 3 main branches to approach to this matter:
__________________________________________________ _______________________
APPROACH 1
Replace Alpina front discs with Alpina front discs and use Mercedes Benz S500/S600 W140 (1994-1998) brake pads.
In December 2006, DaveW posted here (
http://www.m5board.com/vbulletin/sho...7&postcount=26) that he reverted to this solution after trying E32 840 4-Pot Brembo calipers/324mm discs from the 840 with DS2500 pads. This approach has the simplicity of retaining the stock Alpina setup and just changes the brake pads and if desired, upgrade the brake fluid to a higher quality brake fluid to reduce brake fade under hard driving. After trying various solutions, in June 2007 Cor-Jan wrote that he has also returned to using Alpina discs and Mercedes brake pads (
http://www.m5board.com/vbulletin/sho...7&postcount=21)
With this approach, known front brake pads are:
- EBC Red Stuff (front) DP927c USD $92.56
- Akebono Euro689 (technically for Mercedes S600 W140 1994-1998). These are low-dust ceramic brakes for European cars. There are also Ferodo, Axxis and many other choices.
You will have to replace the front brake pad sensor with a BMW one. While
not confirmed, here are two to try:
1996 E38 750iL
Brake pad wear sensor up to 09/1998 34351163117
Brake pad wear sensor 2001 build date 34351165729 (same as the 740d part number)
1998 E38 740d (diesel)
Brake pad wear sensor 34351165729
If you retain the Alpina caliper, you may need to rebuild the caliper at some point. This company will rebuild the BiTurbo Lucas-Girling caliper for you. They can rebuild 'As New' and you can have them finished either in Black or yellow chromate anodised coatings. About £80.00 each plus shipping.
Classicar Automotive
Unit A Alderley Road,
Chelford,
Cheshire,
SK11 9AP, UK,
Tel: +44 1625 860910
Quattroboy (Sean) provided a caliper rebuild alternative for North Americans:
Goldline Brakes
7100 East Marginal Way South
Seattle, WA 98108
877-347-2225
http://www.goldlinebrakes.com/
__________________________________________________ _________________________
APPROACH 2
Replace Alpina front discs with BMW E38 740d or E38 750iL front discs.
The E38 740d front discs measure 334mmx 32mm which is a very close fit to the BiTurbo's 332mm x 32mm. With this setup, the stock Lucas-Girling caliper is retained. The brake pads would be Mercedes Benz S500/S600 W140 (1994-1998) brake pads. This is a cost-effective solution if 290 pounds is not affordable for the
Alpina discs. Kees writes that the E38 740d disc is the same size as the 750iL disc (
http://www.m5board.com/vbulletin/sho...6&postcount=18) and he is correct. I have tried to use RealOEM and can confirm that both discs have the same part numbers.
Europeans can use the following part number:
E38 740d front disc part number: 34116757756 (
http://www.realoem.com/bmw/showparts...18&hg=34&fg=05)
North Americans can use the following part number:
E38 750iL front disc part number: 34116757756 (
1996 E38 750iL
Since you retain the Alpina caliper, you may need to rebuild the caliper at some point. This company will rebuild the BiTurbo Lucas-Girling caliper for you. They can rebuild 'As New' and you can have them finished either in Black or yellow chromate anodised coatings. About £80.00 each plus shipping.
Chelford,
Cheshire,
SK11 9AP, UK,
Goldline Brakes
Seattle, WA 98108
877-347-2225
__________________________________________________ __________________________
APPROACH 3
Replace calipers and rotors entirely.
With this approach, there have been two variations:
a. Replace with a BMW model of caliper and discs
b. Replace with non-BMW calipers and discs
3a Replace with a BMW model of caliper and discs
Possible solutions include:
- calipers from the B12 5.7 Coupé, BMW 850csi or BMW M5 -95. This would allow a 345mm sized disc.
BMW 840Ci brakes on a BiTurbo?
840ci Brakes on Bi-Turbo???
BMW 850 CSI brakes and calipers on 18" wheels
Alpina Biturbo rolling road result
Brakes For Biturbo
3b Replace with non-BMW calipers and discs
- AP Racing
- Mov-It
Breaks on the BiTurbo
- Porsche GT3
__________________________________________________ ___________________________
RESEARCH THREADS for more reading:
Brake discs for B10 Biturbo
Porsche GT3 calipers onto BT?
Brake question Biturbo
Groaning brakes
Bi-Turbo Brakes
REAR BRAKE PADS
BMW # 34 21 1 158 221
Used on : E34 M5 3.6 (from 10/89) & 3.8 (till 06/94) / E32 750i(L) (till 01/90) Original manufactor : Jurid (Type) 547
