Originally Posted by BerlinThunder
Sean, the MB Sensors work with 1 wire. BMW ones need 2 of them. The MB sensors fit but you need to re-wire the whole thing. One of the BMW wires should go to ground (chassis) the other one to the MB wear sensor. That probably should work. What about ordering OEM parts from Alpina? Shouldn´t be expensive.
Well, just received the MB sensor and you are correct, its one wire. It will not work as I've determined that the MB brake sensor has a plastic sheath around the conductor and when it wears, it completes a circuit to ground triggering the warning light.
On the BMW, its the opposite. The sensor is a loop and is a completed circuit when good and when the wire breaks, the continuity is lost and triggers the warning light.
The only way to make the OEM one work with MB pads to either modify the sensor or modify the pad. I'll figure out something or worst case insert a jumper in the circuit to "fool" the warning light.
By the way, the original Alpina sensor is a standard BMW part.
