Puppy.. THIS IS A FANTASTIC job you have done here
I am have a brake/steering problem with my car
Have just changed every sealing in the calibers front and rear,,
the front disk are almost NEW,, but the pads are not oem
put new pads in rear ((ATE)) . new fluid
I have also changed controlarm rubber and used from 750/M5/540
re-adjust the wheel setup ... also took care of the steering column,,
BUT the brakes are CRAP and the car is shaken on loads,,
I will soon take the disc off,, let a machinist take 0.1-0.5 mm off and buy a new S 600 W140 pads
why dont you try it with the original pads and see if it still shakes
shes alpina blue with two turbos and kills m5s her name is m5 killer...then theres hartge e30 cab with a monster engine her name is bird and shes a naughty girl. then theres the other cabrio the 320 clk jasper blue with every extra available. oh yes and the 4x4 cossie she only comes out for a laugh.....and weve now got bird2 shes got 470 horses two turbos and is japanese (SUPRA)......also being added R1 yamaha and a monster 4wd japanese killer just for fun in the mountainsalso just added to the fleet is a 2002 porsche 996tt in silver full options and auto with the old tip-tronicjust arrived vw touareg v10 tdi diamond black, fully loaded tiptronic with 22" rims. just arrived gunmetal grey toyota celica gt4 2.0 turbo 4wd 360 bhp with t4 turbo, running out of space for cars, RS4 CABRIOLET IN PHANTOM BLACK JUST LANDED
By the way, there is a place closer to Canada and USA folk that will rebuild Girling calipers. I did contact them last year and spoke with a very knowledgeable gentleman, but I forgot how much he quoted.
If you retain the Alpina caliper, you may need to rebuild the caliper at some point. This company will rebuild the BiTurbo Lucas-Girling caliper for you. They can rebuild 'As New' and you can have them finished either in Black or yellow chromate anodised coatings. About £80.00 each plus shipping.
Classicar Automotive
Unit A Alderley Road,
Chelford,
Cheshire,
SK11 9AP, UK,
Tel: +44 1625 860910
Based on the recommendation of my supplier, we are going to try this wear sensor after comparing the the photo of the sensor on my car with his parts inventory. I will update once I fit the part. I have attached a picture of the wear sensor mounted to a set of the brake pads to a 540i as an illustration.
